While searching out the correct hardware used in the Army Soldier Plate Carrier System SPCS, I accidentally found this steal of a steel parts deal, an IOTV/SPCS Upgrade/Repair Kit, issued to CIF and deploying units to allow the Joe the ability to repair/upgrade or replace lost/worn/broken parts. It contains 25ea of 5 differnt ITW-Nexus hardware used in the IOTV/SPCS and other pieces of issue kit. Contains the following, all in current US Army Coyote Tan499 (not USMC Coyote Brown Tan498):
25each ITW 1" Oval Sliders
25each ITW 1" Welded Oval Loops
25each ITW 2" to 1" Adapters
25each ITW 2" Bowed Triglides
25each ITW 1" Repair Duckbill Ladder Locs
The kit weighs over 2lbs, so you might as well consider you are getting everything for $6 after USPS. The 2" Bowed Triglides are pretty much unobtanium unless you want to order 3,000pcs from ITW. The Oval Sliders can fetch $0.75-0.99each retail, about $0.24each wholesale.
http://www.ebay.com/itm/IOTV-Gen-II-ucp-Buckle-Kit-Improved-Tactical-Vest-Equipment-Armor-Upgrade-Coyote/391554124266
