Author Topic: 6x3 chest rig panel laser cut from 500D/wide loop laminate  (Read 1620 times)
  • Liked: 287
« on: November 23, 2016, 06:47:03 PM »
6x3 chest rig panel laser cut from 500D/wide loop laminate.  1.5oz / 43g
Re: 6x3 chest rig panel laser cut from 500D/wide loop laminate
« Reply #1 on: November 24, 2016, 02:31:08 PM »
How do you find that MultiCam Loop holds up as a laminated component? Is it Velcro or Propel?
stimpy
« Reply #2 on: November 24, 2016, 03:30:53 PM »
I like the idea, and can see many uses for it. For example as a replacement for a velcro liner inside bags, so that in addition to velcro backed pouches you could attach molle pouches as well. I would actually be interested in buying a large sheet of this that i could cut to size for this purpose and use it in packs .
« Reply #3 on: November 24, 2016, 04:47:22 PM »
Just as a be careful note, First-Spears 6/12 is currently Patent Pending, which is the same as this.
« Reply #4 on: November 24, 2016, 08:38:09 PM »
That's a good point. I think the FS 6/12 is the same as the loopside on Velcro One-wrap, not the same material as milspec Velcro Loop. Functionally similar enough though.
die_dunkelheit
  • Likes Given: 18
« Reply #5 on: November 24, 2016, 10:57:28 PM »
It is worth reading the patent for sure. You're probably okay though if you are using it with the loop facing forward as stimpy suggested for cross-comparability with hook backed pouches.
