Author Topic: XPac VX07 pack  (Read 2628 times)
  • Likes Given: 25
XPac VX07 pack
« on: January 27, 2017, 01:13:41 PM »
I posted this over on DIYTactical when I first made it, but I've been using it a bunch as my everyday hauler, so I thought I would repost it over here to share and get feedback.  This pack is designed as a simple, clean urban pack.
Fabric is Dimension Polyant VX07 XPac. 3mm Spacer mesh back panel glued to 3/8 closed cell foam. Interior key clip, laptop/hydration pouch (sized for 13" MacBook Pro) with stretch mesh panels. all seams are taped with venture tape, stitched and then bound with 5038 grosgrain. The top is a simple roll top with a magnetic clasp and the custom fabricated aluminum hook buckle. No waist belt or sternum strap on purpose, though I would likely add them to future versions. White because it's what I had around from some bike frame bag builds.
Pack by Corvus Threadworks, on Flickr
Pack back panel by Corvus Threadworks, on Flickr
Back panel detail by Corvus Threadworks, on Flickr
Re: XPac VX07 pack
« Reply #1 on: January 27, 2017, 07:51:50 PM »
This pack has two things I LOVE... Xpac and a roll-top.
Personally, I'd put the top strap that the buckle attaches to in the seam of the back panel. That would give the pack a slightly greater adjustment range. (Though, you did say that this pack is for your personal use, so having the webbing placed there for your use may be in a perfect position.) You could daisy chain stitch the top piece of webbing for a greater clipping area with the metal buckle.
For a production model  pack for retail, you could easily add vertical webbing on the should straps for a sternum strap and fro-glides towards the bottom of the pack for an optional waist strap.
Great pack!
I would love to see how you bind you seams. I serge the edges together then use 5038 when I use Xpac. Haven't had an issue yet
  • Likes Given: 25
Re: XPac VX07 pack
« Reply #2 on: February 10, 2017, 03:24:57 PM »
Thanks Globe,
Your thoughts on the webbing placement for the hook are right on, and I would do the same in the future, it is daisy chained, so there is some adjustment, but attaching into the seam would certainly make a stronger and cleaner build.
Good ideas on simple changes to add sternum and waist belt attachments, thanks!
