Author Topic: 3M Adhesive Transfer Tape 300LSE, 24 in x 36 in 61 cm x 91 cm  (Read 1019 times)
  • Liked: 297
3M Adhesive Transfer Tape 300LSE, 24 in x 36 in  61 cm x 91 cm used for making laser cut laminate patches and similar.
click here to buy-->  http://bit.ly/2M8ylOB
Re: 3M Adhesive Transfer Tape 300LSE, 24 in x 36 in 61 cm x 91 cm
« Reply #1 on: May 28, 2019, 02:48:49 PM »
Right on, I just purchased 3 sheets to experiment with.
Do I need a heat press to activate the adhesive?
Do you think there would be a benefit of using a thicker laminated fabric for the base color? For more stiffness?
Thanks, Scott
  • Liked: 297
« Reply #2 on: May 28, 2019, 04:19:19 PM »
Thanks, Scott
Thank you!  The description was just modified to indicate a few extra days to ship.  We got to the bottom and the last 4 sheets were destroyed due to improper storage.  Less than a week to ship from 28MAY2019.
No heat press required.  It's PSA (pressure sensitive adhesive).  A dry press might not hurt.
Depending on the desired hand, a laminate may provide the stiffness you're after.
sawlaw1
  • Likes Given: 8
« Reply #3 on: May 29, 2019, 06:27:31 AM »
Do you think this would work if I wanted to wrap Safariland Kydex holsters?
  • Liked: 297
« Reply #4 on: May 29, 2019, 07:06:18 AM »
I don't know.  I can only comment on using it for laser cut patches and scraps getting stuck to my soles.
Kord
  • Likes Given: 19
« Reply #5 on: June 03, 2019, 10:14:53 AM »
I have seen on the net somewhere that someone tried a similar process using a cheap vacuum bag and a shop vac to "seal" it on to the kydex, if I remember correctly they said it worked but it wasn't an easy process and not one they wanted to repeat.  I have stuck some on mostly flat kydex and it seems to hold well but I haven't seen it after a year of use.  Also I think Safariland uses boltaron but I don't think that would matter much.
