Author Topic: ID This Hardware  (Read 3406 times)
ID This Hardware
« on: February 22, 2015, 10:11:49 AM »
Okay, been trying to figure out what company makes this hardware.  This is on a London Bridge Trading pack.
Then while going through other things I found these.  They look like the ITW G-Hook, but have the same stamp as the LBT pack hardware.
I took these photos of G-Hooks with the Waterbury "W and oval" stamp next to metal stamped hardware bearing "AB."
Any ideas?
Shaddox Tactical
  • Liked: 15
  • Likes Given: 117
Re: ID This Hardware
« Reply #1 on: February 22, 2015, 01:18:30 PM »
I do believe that is an ITW Waterbury steel double bar buckle.  ITW Waterbury part number 00648-09-21883.  I know Lowy USA sells them under part number TB4042, but I think they are special order item so you may be looking at a substantial minimum purchase lot a lot of 1000.  I'm not sure who else might carry them.
Clay- Shaddox Tactical LLC
« Reply #2 on: February 22, 2015, 01:37:24 PM »
Thanks. I know it looks like an ITW item. What is throwing me off is the "AB" stamp rather than the Oval "W" stamped on it.
Shaddox Tactical
  • Liked: 15
  • Likes Given: 117
« Reply #3 on: February 22, 2015, 01:49:42 PM »
I knew I recognized that AB.  It's from Albest Hardware.  Part number GVT840B http://albest.com/product.asp?Func=Info&SelCat=Military%20Spec%20Hardware&SelSubCat=Buckle&SubFunc=Prod&Albest_Part_Number=GVT840B&Prod_Desc=Non+Slip%2C+Tongless+Buckle
I haven't ordered from them in years and was thinking that was Waterbury hardware since that's what I mostly have now days.
« Reply #4 on: February 22, 2015, 02:43:59 PM »
So the G-Hook looking pieces have the AB on them as well, I can't even remember where I got them.  I had mixed them in with the ITW G-Hooks.  Are they a good quality product, I'm assuming if someone as big as LBT uses them they must meet specs.
  • Liked: 115
  • Likes Given: 73
« Reply #5 on: February 22, 2015, 05:11:23 PM »
I picked up a few hundred of those G-hooks with the AB on them from Gerald Schwartz Inc last year, when I couldn't source the ITW brand. The are a very good quality product.
Shaddox Tactical
  • Liked: 15
  • Likes Given: 117
« Reply #6 on: February 22, 2015, 06:21:20 PM »
I've never had any problem with the hardware I got from Albest.  I used to get all of my metal hardware from them and will continue to buy more in the future.
Disturbed
  • Liked: 22
« Reply #7 on: February 23, 2015, 05:59:31 PM »
We use the AB marked fittings from GSI, they do tan flat slides as well.  Never had an issue with them.
  • Liked: 22
« Reply #8 on: February 24, 2015, 07:50:19 AM »
Allbest HK hooks are very GTG.
However I found that the tan colored AB parts have the coating wear out quickly (just storing them in a loose bag will mark the paint). I mostly use black so no big issue.
