Author Topic: What are you using for grommets on pouches?  (Read 2666 times)
« on: March 30, 2015, 02:54:54 PM »
I am currently using the C.S. Osborn anodized grommets size 0, with a press n snap tool. It looks like they are Brass material that is anodized black. They are a U.S. product, so that's why I started using them. Is there another product that I should look at?
Thanks Scott
Re: What are you using for grommets on pouches?
« Reply #1 on: March 30, 2015, 06:31:36 PM »
I would think they are fine.  I use Fasnap size O, they are also brass with some sort of paint.  I have COY498 and TAN499 with the paint, then they have two versions of black, anodized and enamel.  They are also a U.S. product.  I am using the Press N' Snap too, love it.
@less@ndro
    • 9minuti.it
  • Liked: 75
  • Likes Given: 120
« Reply #2 on: March 31, 2015, 01:18:15 AM »
another C.S. Osborn user here, the quality of their tool is really good. i started with the kit for grommets (http://www.csosborne.com/NOK231.HTM) and snaps (http://www.csosborne.com/snap_setter_no_230.htm) and then i bought also the revolving punch (http://www.csosborne.com/NO155.HTM) a bit expensive but you can feel the quality.
Website: www.9minuti.it          A smart back panel for backpain www.smileBack.cloud
Facebook page: https://www.facebook.com/chiocciolabstudio
« Reply #3 on: April 28, 2015, 08:39:06 PM »
I've been using CS Osborne black oxided brass grommets with Midget Setter for years.
I also use #4 and #5 spur grommets with the industrial setting die from a GI Tent Repair Kit that was given to me.  It came with the #4 and #5 industrial setting dies, the hole punches, sewing palm, hand sewing awl, a couple hundred spur grommets, rawhide hammer, patching materials, adhesive, 3 strand cotton shoe thread and #138 OD nylon thread.  Like this one:
http://www.ebay.com/itm/Vintage-US-Army-Canvas-Tent-Repair-Kit-/281676716278?pt=LH_DefaultDomain_0&hash=item41953d98f6
http://www.ebay.com/itm/Vintage-US-Army-Tent-Repair-Kit-/181467759222?pt=LH_DefaultDomain_0&hash=item2a40524276
http://www.ebay.com/itm/MILITARY-ISSUE-TENT-REPAIR-KIT-APPEARS-COMPLETE-AND-NEW-CANVAS-OR-VYNLE-/130896278146?pt=LH_DefaultDomain_0&hash=item1e7a06b282
Kinda ironic considering I turned down the only slot available at 5/19SFG, Tent Repair Specialist. I felt insulted being an accomplished Mortar Maggot, a Warrior.  Assumed  I would just be the  Company Bitch Boy stuck on KP every drill weekend. I didn't see the big picture, that  I could have been doing the same thing I do now, making custom gear or rigger mods to gear for the Team long tabbers, and tasked out to enhance mortar fire as needed.
« Reply #4 on: December 29, 2015, 04:15:41 PM »
I'm looking at adding grommets to my pouches, but I don't know which size and tools I need. I've seen some grommets that are lower quality and others that look and feel sturdier. What do you guys recommend? I like the one on the bottom of the Maxpedition Rollypoly (pic below). It's 11/16" dia with a 5/16" hole and a rounded profile. This would be good for larger utility pouches etc. Maybe a slightly smaller one for mag pouches.
Any help appreciated!
Right Side Gear
« Reply #5 on: December 29, 2015, 09:27:11 PM »
I use Scovill fasteners.
http://www.dotfasteners.com/index.html
I use the rolled rim grommets and washers size #1. I also get my snaps from them, they are the makers of Pull-The-Dot snaps.
I use the General Tools 3/8 setter kit, it's a hand setter kit.
http://www.generaltools.com/hand-tools/special-purpose-tools/grommets/3-8-in-grommet-kit.html
Sent from my iPhone using Tapatalk
« Reply #6 on: December 29, 2015, 10:55:49 PM »
Thanks for the reply! I'm going to check out the rolled rim grommets and washers, as that's what I think this one is. I'll post results when I have some.
« Reply #7 on: January 22, 2016, 04:55:18 PM »
I ended up buying a hand press with a set of dies and a 1/4" jam for cutting the hole in the fabric. For grommets, I went with a rolled rim or spur grommet and washer in size #00. The next size up seemed too large for small pouch applications. These are a black oxide finish.
die_dunkelheit
  • Likes Given: 18
« Reply #8 on: January 22, 2016, 06:00:54 PM »
What is the proper name for the grommets with a mesh screen like on a boonie?
