Author Topic: 1 yard of 200 dinar nylon multi-cam  (Read 1173 times)
Byron375
« on: July 19, 2015, 03:12:11 PM »
gentleman I need help. I am trying to find 1 yard of 200 denar nylon multicam fabric. Can anyone help with A contact or source.
Re: 1 yard of 200 dinar nylon multi-cam
« Reply #1 on: July 19, 2015, 03:25:03 PM »
The only Denier I have close to that is 330D Multicam.
Byron375
« Reply #2 on: July 19, 2015, 07:02:36 PM »
Has to 200 D because it is for a commercial dive helmet liner called a snoopy. Thanks brother I need all the help I can get trying to find it seems nobody carries it
« Reply #3 on: July 22, 2015, 02:36:22 PM »
Just curious, why does a liner need to be a particular color?
  • Likes Given: 29
« Reply #4 on: July 22, 2015, 05:29:05 PM »
Are you maybe looking for  200d Oxford fabric? I don't think anyone makes a 200d cordura...
« Reply #5 on: July 31, 2015, 08:32:46 PM »
A little off topic here, but which kind of commercial dive helmet?  I used to dive the Kirby Morgan SL 17.  We upgraded them with the quad exhaust after a few years, and I think that made them equivalent to the 47 or something.
« Reply #6 on: August 01, 2015, 12:51:24 PM »
I see Multicam Taslan/Taslite available rather reasonable.  Its a lightweight water resistant fabric would work well with some thinsulate or primaloft for your dive hood..
This is being sold as Nylon Poplin DWR would probably be as close to 200d that you will be able to get without a custom order with X,xxx minimum yardage:
http://www.ebay.com/itm/MULTICAM-NYLON-POPLIN-CAMOUFLAGE-FABRIC-MILITARY-48-W-CAMO-DWR-BY-THE-YARD-/321820345521?hash=item4aedfcc4b1
You want the water vapor condensation drops to run off the hood instead of soaking in reducing the insulation efficiency, right?
Items like these are not regular catalog item for the Multicam line. These are overrun fabric from specialized orders for companies like Patagonia, Arc'teryx, etc, that special order the superlight high performance fabrics for like Patagonia's L8 and L9 Temperate and Jungle-style uniforms.
« Reply #7 on: August 01, 2015, 05:33:06 PM »
I have dealt with that seller in the past and he is good guy to work with, I know he said multicam has dried up on the ends etc. Since the supplier change.
