Author Topic: Loop Material 60" Wide by the Yard  (Read 1514 times)
« on: January 08, 2016, 09:13:57 AM »
I am currently in need of Loop material by the sheet. I have been unsuccessful in finding solid colors by the yard, small minimums. I am interested in solid colors to line a bags and/or pouches with. Right now I'm interested in colors similar to Tan499, Foliage, Wolf, Urban, etc... I'm not too picky at the moment as it will be a lining material. Does anyone have what I'm looking for or have a source?
There was another post made: http://gearmaker.org/index.php?topic=254.msg1060#msg1060
This one however, was asking about Loop material that is softer, ie like the linings that Vertx uses inside their bags/pouches. I don't have a lot of experience with this type of hook and I'm slightly skeptical of it for that reason. I'm not concerned with weight or flexibility with my current projects.
Thank you!
« Last Edit: January 08, 2016, 10:54:42 AM by Globe »
Re: Hook Material 60" Wide by the Yard
« Reply #1 on: January 08, 2016, 10:17:59 AM »
Just a quick clarification, did you really want "hook" material to line bags with, and not "loop"?
Re: Loop Material 60" Wide by the Yard
« Reply #2 on: January 08, 2016, 10:55:38 AM »
Thanks for the catch Scott! I edited the title and my post to reflect the correction.
« Reply #3 on: January 08, 2016, 11:14:09 AM »
There are kind of two ways you can go with this.  There is the actual Velcro style loop, which is a little pricy for 60 inch wide fabric.  There is also the generic "not really loop" stuff that works fine for low cycle applications.  It looks and feels more like a regular fabric than velcro style loop.  I hade a safe liner with this by gaping and seing it to a piece of HDPE, and put elastic mag organizers on it, and it's fine.  That being said, I don't plan on pulling the mag holders off and putting them on every day, so it really is a low cycle application.
Low Cycle
http://www.rockywoods.com/Hardware-Zippers/Velcro-Tape-Fasteners/Black-Generic-Loop-Sheet
High Cycle (true loop)
http://www.rockywoods.com/Hardware-Zippers/Velcro-Tape-Fasteners/High-Cycle-Loop-Sheeting-Black
« Reply #4 on: January 08, 2016, 03:10:28 PM »
I'm planning on initially using this in a range bag, so I'm predicting high cycle use.
Rocky woods only carries black. I'm definitely looking for a lighter solid color.
I really want to avoid lining up 4" strips to fill the area.
